digital camera ABB commnication
Jurong
Is it possible to send command to a normal digital camera using RobotStudio? All I need is to automatically trigger the shutter when the robot arm is in desired position.
If your digital camera has a trigger input, you can wire it to a discrete output from the robot controller i/o.
Make sure the voltages are compatible. If they are not (for example, the controller i/o may be 24vdc and the camera trigger may be 12vdc) then use an isolation stage, like opto-isolator is a good choice.
Also pay attention to the camera's trigger-state. It is common for the trigger to operate in different modes, depending on camera settings.
If the trigger is rising edge active, the one example of RAPID would be; Reset Camera_Trigger; PulseDo \High \PLength:=.03, Camera_Trigger;
M. McGraw
<font face="Verdana, Arial, Helvetica0 -
Thanks for your comments. I will it a try.
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
