Importing Geometry from SolidWorks using the same car-zero origin
I was wondering if it was possible to import SolidWorks drawings in to RobotStudio while maintaining the original car-zero origin.
Thank you in advance
I have done this using ProE without any problems.
When you export your .sat you must pick the coordinate system from ICP in the model.
