PlasticMould Virtual Controller
I have been asked to create a virtual system with the Plasitcs Mould option.
The system starts up ok but should I see a dedicated plastics GUI in the FlexPendant ABB button?
Should the Plastics Mould option be accompanied with other options?
I have installed the RobotWare plastics from the additional options found on the RW 5.15.01 DVD
Many thanks for any advice
  • You need to install the RobotWarePlastics Additional Option from the RobotWare DVD. You need also to add the option key when configuring your system in System Builder. The option key is in the MediaPool RobotWarePlastics / InternalUseKey folder. Select the RW Plastics option in System Builder. As a note, Robotware Plastics is being replaced with Robot Studio Machine Tending PowerPac and RobotWare Machine Tending.
