Caculate robtarget.
Simotion
I want to calculate a robtarget, with the property that the rotation of the tool is halfway between the rotations of the points before and after my newly calculated robtarget.
So I have a robtarget to start the movement, this robtarget is known, I have an endpoint of the movement, also a known robtarget, and finally I want to create a point between both, where the rotations are halfway between start and end, to create a fluent transition from start to end, and where the rotation of the tool is done over the whole distance between start and end.
Start- and endpoint have the usual notation with quaternions to define the rotoation of the tool.
Question: Are you trying to do this from the RobotStudio UI, an add-in or from RAPID?Anyway, the nice thing with quaternions is how easy it is to interpolate orientations with them. Search for slerp or quaternion interpolation if you interested in more details.For a RobotStudio add-in, look at the Quaternion class, and its Interpolate() method.You will also have to do a linear interpolation (lerp) of the target positions. For add-ins, look at the LinearInterpolate() method on the Vector3 class./AndersAnders Ekelund
Architect, RobotStudio
ABB0
