Developing FlexPendant app with 5.15 - does VS2008 still work?
Hi, I'm new to developing a FlexPendant app, and I'm not clear on what the support currently is.
I understand VS2010 and VS2012 can't be used due to the (lack of) Compact Framework, but I also have Visual Studio 2008 Pro, and have just installed RS 5.15. When I start VS2008 I do not have any options to create a new FP project in C#.
Do I need to install RS 5.14 to get started? Or do I mock up my UI in ScreenMaker and then save as a FP SDK project so I can continue in VS2008 and get the full power of the .Net runtime?
Thanks,
Derek.
I had the same issue. Uninstalling and reinstalling RobotStudio fixed it for me.0
Thanks baldwindc - simply reinstalling it didn't work, as you say, it had to be uninstalled fully before reinstalling to insert the FP project options in VS2008.0
