How to make a custom function in my rapid program?
Can I make myself a function the same way I make a procedure in RAPID programming? If yes then what is the proper syntax for it?
  • Here is an example of a simple function. FUNC num abs_value(num value) IF value<0 THEN RETURN -value; ELSE RETURN value; ENDIF ENDFUNC gr, Richard
  • Thanks, I didn't declare the function type ;)
  • Hi, Just wondering how can you make the custom functions global? Do you need to declare in a header file or something and include the header file in your main?
    Regards
    Kent
  • Micky
    Micky ✭✭✭
    all procedures, functions and data declarations are defined as global in a Task if the argument "LOCAL" is not used.
    Examples for global declarations:
    CONST num nMyNum:=1;
    PROC MyProc()
    FUNC num MyFunc()
    Examples for local declarations in a module:
    LOCAL CONST num nMyNum:=1;
    LOCAL PROC MyProc()
    LOCAL FUNC num MyFunc()
    If you are using a persistant data declaration, you have the following possibilties
    PERS num nMyNum:=0;    (Persistant is defined as global for all tasks, in case of same declaration is available in the other tasks
    LOCAL PERS num nMyNum:=0; (Persistant is only available in the module)
    TASK PERS num nMyNum:=0; (Persistant is global in the current task)
    Regards
    Micky
