RobotStudio 5.15.01 - Unable to Remove Unused Targets
I found an issue that prevents the removal of unused targets. The image below shows targets still remaining even though no paths are currently in the RS station.
Thanks,
Marcus
I see that you use a lot of white spaces for the controller system name. I am not sure the VC feels good about that. In any case, I would like to take a look at your station. Please send a Pack&Go file to your local ABB representative. He (or she) can forward it to the RobotStudio tech support.Henrik Berlin
This happened after he was selected in the dialog box."Do not ask again."This happened to me and do not know how to return0
Click in File -> Options
in dialog: OptionsMarkRestore hidden dialogs and messagesClick Button ApplyAnd test newer0 -
Hendrik,That white space isn't really white space, I just deleted that out of the Jpeg...there was text there, but it was a customer name.alexsdm,That worked, I appreciate it!
Thanks,
Marcus0
- 367 IRC5
- 858 RAPID Programming
