Mechanism
Can you pleeeeeze help me make a mechanism that simulates a 40 Meter servotrack for a robot . I did what you said regarding the mechanism topic but i keep getting fatal errors. I have a customer that is getting
because I can't simulate the 100 foot gantry. We are in desperate need of having this. The success of this simulation would help our project a lot. Also how can I hold the title of "power user #2, KPS is #1" if I cannot make a 100 foot track. LOL Your help is greatly appreciated.
Best Regards
lil jon.....YEAH, WHAT!!!
Here is a 40 meter track you can use to get your customer happy
Thank yo very much...by the way, do i need a corresponding configuration file? I will get the error " track doesn't match config file"? Thank you
lil jon
Eric_G0 -
First you need to create a system that have support for external axis. Then you have to add a configuration file for the track with the correct working range.
How to do this is explained in the RobotStudio Online Help.
The attached config file have a working range of 40 meter.
ABB Robotics0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
