How to transfer station/virtual controller to robot/real controller in 5.13?
I have programmed a simple movement routine in my station. How do I generate a program file so that I can open it with my pendant on the real controller?
  • In Robotstudio 5.15 you may use the new feature "Transfer" where you set up a relation between your virtual controller in the station and the real controller.
    So if you have created a path in your station, you synchronize it to the virtual controller, from there you may transfer it to the real controller, if your are connected to it via ethernet.
    If not connected, you may save the RAPID module from the Editor to your PC and use a USB stick to load it into the controller...
    A question: With 5.13 you mean the RobotWare in the real controller - or??
    regards
    Christian
