Internal error messages
belthar
Hello! I've got an IRB2400 S4C ABB Arc welding robot. Sometimes
the Teach Pendant shows the following internal messages, and I don't
know what does these mean.<br>- cabts.c 7389 Regain on path not possible one client has already order it<br>- tsksup.c 165 Assert: p -> use_count > 0, file segm.c, line 720 <br>Could somebody help me? Thanks<br>
Don't know if this helps but you should check out your Event Log and see the events surrounding that one.
Now "the regain not possible"..etc is this event:
10054, Regain rejected
Description
Regain on path not possible, as one client has already ordered it.
Recommended actions
A new regain movement is ordered during an already started regain movement. Reduce the number of start orders from e.g
system I/OSo you should also check if you have an external source requesting multiple starts when the controller has stopped.
John
Developer Center0
