S4 System Disk
mkcho501
Hello,<br><br>Our company just bought IRB 1400 robot from other
company. I'm trying to make a cold reboot for IRB 1400 S4 controller,
but I've got problems with the controllers. When I inserted "key disk",
the teach pendant display appear "insert Program3HAC2700-2 system disk".
I have the key disk, but don't have the boot disk. Is there anybody have the boot disk or boot files
so that I can continue the installation
You can contact your country ABB robotic office to get roboware 3.20
Get in touch with your local ABB Robotics office and they'll help you out.
The disks you need depends on the controller being S4 or S4C and what type of main computer you have
so give them the serial # and the DSQC # off of the boards you have in the front when opening the door
and they can help you get what you need.Nirmala DeviABB Holdings Sdn Bhd
Lot 608, Jalan SS13/1K
47500 Subang Jaya
Selangor Darul Ehsan
Malaysia
Tel: +603 5628 4888
Fax: +603 5632 78890 -
Type text or a website address or translate a document.Did you mean: سلام شما بايستي انتخاب كنيد ورژن بر طبق مدل كامپيوترHi
You should select the reboot version of the computer model.
You can read the attachment that helps you to choose the version0
- 361 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
