How to configure Ethernet IP M/S (841-1, no PCI fieldbus board).
pacijent
Hello, we just got robot with Ethernet IP M/S option (841-1), it doesn't have PCI card, it's using IRC 5 computer's Ethernet port for fieldbus communication. I'd like to know how to configure this type of communication, I can only see Ethernet slave unit types inside robot configuration options, and in manual they described how to set this communication in the case we have PCI board. I don't know how to do it without board. Thanks.
Is this the EtherNet/IP Fieldbus Adapter for EtherNet/IP I/O, or are you doing something different?
No, this is not fieldbus adapter, this is Ethernet IP M/S software option.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
