Robot won't "move to" between targets with different tools
in PowerPacs
I am working in the AWPP and having this issue. I am almost certain that I have done this in past versions of RS. I am currently running RS 5.15.01 and the same AWPP. "Jump To" works, but "move to" fails. I have seen issues like this before that are resolved by a slight modification of the target to "refresh" it, but this is definitely related to the change in tool between targets.
I second that. I run into this problem all the time!
Thanks,
Marcus0 -
hmm,
I am using version 5.15.02 and that got rit of al lot of bugs, maybe updating will resolve this problem also?
I Always use the same tool (weldinggun) so got no experience there with this new update
