media pool issue
Laro88
For some reason I am not capable of editing a system using the System Builder.
I get an error when I try so save the new config.
"The RobotWare version of the system (or RobotWare files.... yada yada.
I uninstalled Robot studio and all installed RobotWare versions but still nogo.
Any suggestions are more than wellcome.
Hello,I have the same problem. I have installed RS and Robotware(5.15) into my laptop and everything works normally(during creating/modify system). When I install RS and RW(same installation files-http://www.abb.com/product/ap/seitp327/a1078d9e5145d9a9c1257991004f3e69.aspx) into my desktop computer , and try to create/modify system, the same error as above appears. Has anybody solved this problem.Thank you0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
