Remove apps from the Flexpendant
in ScreenMaker
Hello!
I just started to try creating screens in ScreenMaker in the newest Robotstudio version. Right now I'm connected to a VC and transfered a project to the flexpendant. But now to my question, how do I remove the project from the flexpendant?
/erik
You have to remove the two dll files in the home directory.Regards
Knud Erik Lindberg
Danrobotics5
I can't delete them, "...could not be deleted"Knud E Lindberg said:You have to remove the two dll files in the home directory.0 -
I know this has been solved but a shortcut to delete this files is to close the Virtual FlexPendant - Right Click on the Home Dir in your system - Open Folder - Find and Delete the two .dll file from that directory and restart the system.0
You only need to delete "TpsView.....dll" and "TpsView....gtpu.dll" from Home and restart the system.0
- 367 IRC5
- 858 RAPID Programming
