String to number conversion and checking the reachability in RAPID
pion3k
I need some help with the following problems:
1) Is it possible to somehow convert a string (in my case received through a socket) to the equivalent data but in a number type in RAPID? I have tried with StrToByte but the problem is that I'm significantly limited by the range of the byte type (0 - 255 without negative values). What I need is to send by the socket the position of the robotic arm and, as you know, the position of the effector can quite a bit exceed the limit (255). I thought about multiplying the values but in this case I would lose a possibility of reaching intermediate points. And still, what about negative values?
2) How can I check a reachability of a specified point by a RAPID code? Generally, my program crashes now when the coordinates of the demanded point are exceeding the robot's workspace limit.
Best Answers
hello,
1. you can use strtoval for converting string to numbers
2. you can use CalcJointT for checking reach, if it gives an error ERR_ROBLIMIT then you know the robot cannot reach the position
BR
Peter
5 -
i have found the error it was in the format of using StrToVal5
Hello,i have the same problem , i have this variableVAR string Fx_S1:=0.784184821186377;i have imported from C# addin , and when i use the commandVAR strtoval Fx_S1;it gives me the following error :IRB4400_60kg_1.96m_245/RAPID/T_ROB1/MainModule(3,2): Name error(49): Variable name x_S1 ambiguous. 10/14/2013 8:40:28 PM GeneralChecked: IRB4400_60kg_1.96m_245/RAPID/T_ROB1: 1 semantic errors. 10/14/2013 8:40:28 PM RAPIDany help is really appreciated0
- 365 IRC5
- 84 OmniCore
