Robot won't "move to" between targets with different tools
I am working in the AWPP and having this issue.  I am almost certain that I have done this in past versions of RS.  I am currently running RS 5.15.01 and the same AWPP.  "Jump To" works, but "move to" fails.  I have seen issues like this before that are resolved by a slight modification of the target to "refresh" it, but this is definitely related to the change in tool between targets.
  • I second that.  I run into this problem all the time!
    Thanks,
    Marcus
  • hmm,
    I am using version 5.15.02 and that got rit of al lot of bugs, maybe updating will resolve this problem also?
    I Always use the same tool (weldinggun) so got no experience there with this new update
