Using PickMater 3 and one camera for multiple products
pacijent
Hello to all, please I would need some information about possibilities of usage of PickMaster 3. We might have a need to pick 15 different small parts in order to assemble low voltage breaker. We'd like to do it using PM 3 and least amount of cameras and robots. Now do I need for each part one camera, or can I use one camera to cover let's say two bowls with randomly filled two different kind of parts, and then send signal to two robots from one camera about positions of parts in each those two bowls. Or is there some other possibility to achieve this, basically we would like to apply this solution: http://www.youtube.com/watch?v=txahbz9eswk since we have problem with spacing. Thanks in advance.
If you have the camera distribution option you can have more robots use the same camera, you need to insure that the resolution of the camera, give enough information for image processing.
Regards
Knud Erik Lindberg
Danrobotics0 -
Hi everyone!I occasionally found out this topic. Is there anyone very confident with this add-in for Robot Studio?I need an urgent help with simulating the bin-picking of disordered details (somehow like in topicstarter's video on youtube).Is it possible to generate the random spatial position of similar parts in the box?Thanks!0
