3D scanning station - camera triggering problem
kajlabarna
edited October 2013 in Robot Controller
Dear Users!
I have a very difficult question.
We have a project, where we would like to scan a workpiece with a 3D camera. For linear motion of the camera an ABB robot will be responsible.
The problem is the camera has to be triggered at every 0,1 mm on the linear path.
Unfortunately I did not find such an instruction in the RAPID manual, but I found in the Continuous Application Platform the CapEquiDist instruction, which has a function similar to that I need.
Do you have any information or solution how I could solve this problem?
Thank you for your answer.
Barna Kajla, Automation Engineer
Post edited by kajlabarna on
  • Hi,
    The answer would depend on how fast you are moving with the robot - if you are going too fast then triggering an output every 0.1 mm becomes very difficult.
    What spped are you using?
    Regards
    Graeme
  • Hi!
    The speed of the TCP have to be about 70 mm/s. So it should give 700 pulses in 1 second. I have looked after this, and it is not possible with the standard DIO of the robot.
    Fortunately, we chose another solution how to measure the part.
    Barna Kajla
