Difference between arc moves and welds
When placing a moveJ instruction there are 2 options, with or without arc
I was wondering what the arc instructions are for?
The old s4c+ controller won't recognize them, the new ones with irc5 will.
You can read about it in the manual Arc and Arc Sensor. You find the manual under ?/Applications in RobotStudio.
BR / Henrik
Kga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0 -
The S4 will not recognice a instruction for arc made in RS5, because the instruction is not the sameS4 is feks ArcLon and IRC5 is ArcLstart.Normally you cant use RS5 for programming S4, unless you know exactly where to change and edit in the rapid program.if you need help let me know.Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0 -
Programming of S4 cant be done in RS 5 unless you know where to edit in the rapid code.S4 is ArcLon and Irc5 is ArcLstart and so on.let me know if you need helpKent Zibrandtsen
Thanks for the reactions,
I have made a conversion program to convert irc5 modules to s4c+, all works verry well
The ''arc moveJ'' instructions are simply turned into ''moveJ'' instructions during the conversion.
This way we will never send an arc instruction to the s4c+ robot.
We recently got IRC5 robots, the first IRC5 in our company
And now i was wondering wat the extra ''arc; function is for...
@ herdrik
I have taken a look @ the manual arc and the only arc move related instruction is this one:
ArcMoveExtJ is almost a copy of the MoveExtJ instruction but has integrated error handling for RobotWare Arc.
So it prevends errors??
From the manual (it is for proper error handling):
You can take a look at weld error recovery.
ArcMoveExtJ
ArcMoveAbsJ
ArcMoveL
ArcMoveC
ArcMoveJ
These must be used to have proper error handling when using RobotWare Arc in MultiMove. The installation of the module is done by adding the following to SYS.cfg, where task name represents the name of the additional axis RAPID task name.
BR / Henrik
Ok, thanks for the information, we will be using arc from now on with the new IRC5 robots
greetings, Jasper
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
