Problem
Bellen
How to transfer system signels to the PLC via RS232,such as Motor on, Auto on, etc.
Rob side PLC side
Motor On ----> MR100
Auto On ----> MR101
Post edited by Jonathan Karlsson on
Or is associated with a variable.PERS num RM100;PERS num RM101;Motor On ----> RM100Auto On ----> RM101Thanks0
Bellen,
You will need to define a virtual Output for both signals then you can read the state of the Outputs and set your RM100 and RM101 based on the state of the output. Example:
Define a Virtual board VIO1 under units in configurations
Define a Virtual Output voMotorsOn and connect it to VIO1 board
Define a Virtual Output voAutoOn and connect it to VIO1 board
Define a System Output and connect voMotorsOn to MotorOn system output (this means even if your program is not running the virtual output voMotorsOn will always be updating with the state of MotorOn
Define a System Output and connect voAutoOn to AutoOn
now in your rapid code you would need to read the state of the outputs and update your variables
IF Output(voMotorsOn)=TRUE THEN
RM100:=1;
ELSE
RM100:=0;
ENDIF
IF Output(voAutoOn)=TRUE THEN
RM101:=1;
ELSE
RM101:=0;
ENDIF
Thanks for your help to answer my questions. I will try it next week. If I have further problem, I may need your assistance again. Wish you have nice weekend!Bellen0
I have another question, how to control System Input via RM200,for example,PERS num RM200;PERS num RM201;PERS num RM202;RM200 ----> MotorOnRM201 ----> StartRM202 ----> StopWhat's the difference between Start and StartAtMain signal?Can I put these codes in the Daemon (background program or multitasking), and then set routine to semistatic?Thanks0
I have define a virtual board, then define a virtual output signals both voMotorsOn and voAutoOn, then connect them to system output MotorOn and AutoOn, and checked them at Input and output\View\I/O units\VI01\Signals\voMotorOn and voAutoOn, the states is OK.
then write code in the rapid
RM100:=1;
ELSE
RM100:=0;
ENDIFbut there is an error message appear, Event Message---Output not function reference, how to solve this problem.
