ListView example
Where can I find an example about listview with 3 or 4 columns? headers
BR
Jordi
Jordi Saboya
For c#, VB, etc? Can you be more specific?
Alex
I'm also interested... Howto needed in Developer Center?0
If you're using c# you define the number of columns in the UI designer. Assuming you named your listView scanning_window, something like this should work:this.scanner = new ABB.Robotics.Controllers.Discovery.NetworkScanner();scanner.Scan();ControllerInfoCollection collection = null;if (scanner.Controllers.Count > 0){collection = scanner.Controllers;ListViewItem item = null;scanning_window.Items.Clear();foreach (ControllerInfo controllerInfo in collection){item = new ListViewItem(controllerInfo.IPAddress.ToString());item.SubItems.Add(controllerInfo.Id);item.SubItems.Add(controllerInfo.Availability.ToString());item.SubItems.Add(controllerInfo.IsVirtual.ToString());item.SubItems.Add(controllerInfo.SystemName);item.SubItems.Add(controllerInfo.Version.ToString());item.SubItems.Add(controllerInfo.ControllerName);scanning_window.Items.Add(item);item.Tag = controllerInfo;}}0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
