RAPID: Use signal as parameter in a procedure
The RAPID reference manual states about signalxx type: "The data type can, on the other hand, be used as a parameter when declaring a routine."
I have a routine that uses a signalgo as an input parameter, but RobotStudio throws an error when I check the program.
Am I doing something wrong or is what I'm trying to do not possible?
  • What is the error?
  • Maybe we can help to you when we see error code
  • Was it "signalgo not value type"?
    I've had the same issues. I finally got around it (probably not the most efficient way) by doing a test of the GI:
      TEST GInputDnum(giProgramNum)
            CASE 1:
                rFD4_Blade1;
            CASE 2:
                rFD4_Blade2;
            CASE 3:
                rFD4_Blade3;
    ENDTEST
    In my case I was calling routines directly as a result of the test, but I would imagine you could assign a value to a num data type, then use that num as an input parameter. Of course, that would be difficult and a lot of code if you have a large range of possible GI values, but it worked for me in my situation.
    -Bria
  • Micky
    Micky ✭✭✭
    if you use a signal as parameter for a routine, you have to user the argument "VAR" before the datatype in the routine header.
    Example:
    PROC TestSignal(VAR signalgo signal)
      setgo signal,2;
    Regards
    Micky
