Trap Routines
Ercan
Hello everyone,
I have some questions for you. I want to learn somethng about trap routines. For exaple Why I must use trap routiens? or How can I use that? I need basic samples about this. I found a module aboot Trap routines. But I didnt understand well. I hope you cam help me. Thanks for all
MODULE Warning
VAR intnum nTimeInt_1;
VAR intnum nTimeInt_2;
PERS bool sim_test:=FALSE;
PERS bool OpStart:=TRUE;
PROC main()
!TIME TRAP 1 CONNECTION
IDelete nTimeInt_1;
CONNECT nTimeInt_1 WITH TimeTrap1;
ITimer 1,nTimeInt_1;
!TIME TRAP 2 CONNECTION
IDelete nTimeInt_2;
CONNECT nTimeInt_2 WITH TimeTrap2;
ITimer 0.5,nTimeInt_2;
WHILE TRUE DO
CheckErrorStatus;
SystemStatus;
IF OpStart=FALSE THEN
IF DOutput(bFlash_1)=1 THEN
Set doStReadyLamp;
ELSE
Reset doStReadyLamp;
ENDIF
ELSE
Set doStReadyLamp;
ENDIF
WaitTime 0.3;
ENDWHILE
The manual RAPID Overview that is available in RobotStudio provides a good starting point.
TRAP routines are convenient when you want to interrupt the program flow to act on some external event.
/Henrik
ABB1 -
Thanks Henrik for your informations0
- 364 IRC5
- 83 OmniCore
