error robotstudio : RobotStudio .NET exception: No response from controller.
Base exception: RobApiException
Server stack trace:
Exception rethrown at [0]:
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)
at RobotStudio.Services.Controller.ControllerService.<StartAsync>d__3e.MoveNext()
Exception rethrown at [1]:
at RobotStudio.Services.Controller.ControllerService.<StartAsync>d__34.MoveNext()
Exception rethrown at [2]:
at RobotStudio.Services.Controller.ControllerService.<Start>d__2f.MoveNext()
Exception rethrown at [3]:
at ABBInternal.Controller.StationVirtualControllerManager.<StartNewController>d__10.MoveNext()
after this error robotstudio blocks.
I have this problem on all my existing stations.
the same problem I have at the time I want to add a brand new created controller to a robotstation.
trying to solve the problem I was already uninstalling and installing back robotstudio (5.15.02) but the problem was still persisting
afterwards I was installing version 5.60 but also with this version the problem persist .
does anybody has any idee about what is wrong?
thanks,
bart
Hi Bart,
This is not a known problem and we want to take a closer look at it. Please contact your local ABB Robotics Service representative that can log a support case and submit to our product support team that can take a closer look at your problem. If you do not have an established ABB contact locally, you can check http://www.abb.com/contacts.
Kind regards,
Henrik
ABB0
- 367 IRC5
- 858 RAPID Programming
