Simulation doesn't work anymore
Luxrobotic
Hello gents,
I have a problem to run the simulations of my different stations. A few weeks ago this problem appeared and I don't understand what happened at this time.
When I launch the simulation, the controller starts, but stops after a few seconds, and i have a TimeOut error message:
I tried with stations which where ok before, but also with new stations.
I tried with RS 5.14.03, RS 5.15.02 and with 5.60 without results.
I think it's probably coming from my computer.
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
For some reason the Virtual Controller does not respond to RobotStudio during the simulation.
First thing to check is the virus scanner or host intrusion protection system. Try to disable them and see if it helps.
I this does not help I would recommend you to get in touch with your local ABB representative than can forward your issue to our tech support.
/Henrik
ABB5
Hi Henrik,
thanks, I'll try as soon as I will have time.
Regards,
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110
- 367 IRC5
- 858 RAPID Programming
