How to assign a station to external axis
I have two external axis, but both axis share the same extax value.
How can i assign them to different external axis values?
  • in the parameters for motion (MOC) you can  assign a logical axis.
    MOC -> Joint -> logical axis  7-12 assign to extax.a to extax.f
    6.16.3 Logical Axis
    Parent
    Logical Axis belongs to the type Joint, in the topic Motion.
    Cfg name
    logical_axis
    Description
    Logical Axis defines the axis number as seen by a RAPID program.
    Usage
    The value of Logical Axis is used by RAPID programs to identify individual axes
    in mechanical units.
    Two mechanical units can have the same value set for Logical Axis, but then they
    cannot be activated at the same time by a RAPID program.
    Robots from ABB normally use the values 1-6, while additional axes use 7-12.
    Allowed values
    A value between 1 and 12.
    RobWelding
    The Netherlands
  • Hi, SjoLi.
    I am pretty new to RS.
    How do I change the moc file?
    I can see it under controller tab--> configuration editor-->Moc and there's nothing within Joint.
    I can't add anything. Do you need write permission or something to do so?
