visual studio and widgets
wolfino
After installing the FPSDK 5.60 there is no widget template in Visual studio 2008. Just the 5.60 Screen template. Am I doing something wrong or it is not supported yet?
In the robot studio 5.60 release notes it says that the Visual studio tools for applications has been discontinued and is no loanger available.
What is the reason for discontinuing?
Will it be possible in upcomming versions?
@jasper : If you are looking for using an Addin made with Visual Studio in RobotStudio, please try using a 32 bit version. Hopefully it should work.0
- 88 OmniCore
- 42 AppStudio
