array syntax, loading modules and searching.
Hi Everyone, I'm having a problem with syntax for searching
for an array.
1) I want to load a module in an order
defined by an array:
CONST string
Modules{4}:=["mod1.MOD","mod2.mod","mod3.mod","mod4.mod"];
PROC Load_module()
FOR i FROM 1 TO Dim(Modules,1) DO
Load\Dynamic,diskhome\file:="Modules{i}";
Within this module are a listing of RobTargets, and another
array (called “Positions#” where # will change for each module) defining the position
that I need the robot to work. These are
large – 2000 points and the array with 2000 names in it.
2) Once that module is in memory, I want
to search it to look for the array that contains the robtarget order:
SetDataSearch "robtarget"\Object:="positions.*"\INMOD:="mod{i}.mod"\GlobalSym;
getDataVal
"positions.*",targets;
This is the problem area – I want to assign “positions#” to another
array name “targets” so that my main program can maintain a generic variable
name.
Would someone be able to help with the syntax?
as described in the section "Limitations" in the chapter "SetDatasearch" in the reference Manual it is not possible to search for Arrays.
In this case you can only use the instruction GetDataVal and verify if the error ERR_SYM_ACCESS is not raised, to know if array is available.
To be able to read the Array you have to define another array defined with the same size as variable (VAR) and use this as Parameter for GetDataval instruction.
e.g.
FUNC bool ReadArray(num Index)
VAR robtarget pArray{2000};
GetDataVal "Positions"+ValtoToStr(Index),pArray;
RETURN true;
ERROR
!Array not available
IF ERRNO= ERR_SYM_ACCESS RETURN FALSE;
Hi Micky, Thanks for the reply. I didn't have my notifications set to email when someone posted.
I'll have a look at what you're suggesting. it looks like it should work.
Darren
Micky said:Hi,
e.g.
RETURN true;
ERROR
