IRC5 controller Backup to a server
hello everyone
if I wanted to preform scheduled backups of my IRC5 controller through the LAN port to a server, how would I configure this. do I need to have any additional software or add on packages.
thank you
Either you use standard system input "Backup", read details in Technical Reference Manual "System Parameters" on how to use
or
Add option PCSDK and build your own PC application0 -
You'll need the option ftp/NFS server to hook the robot up to your network.You can tie a input to an event and as such generate a backup, this is done throughan external PLC or a background task (option MultiTasking).// Magnus0
