Problem with offsettitng the Path[Moved]
I have problem with offsetting path, which uses external axis. How offset the path with including change of value external axsis ? I have tried this:
CONST robtarget Target_280:=[[355,0,6000],[0.707106781,0,-0.707106781,0],[-1,0,-2,0],[5650,9E9,9E9,9E9,0,9E9]];
CONST robtarget Target_290:=[[0,-355,6000],[0.5,-0.5,-0.5,-0.5],[-1,0,-2,0],[5650,9E9,9E9,9E9,90,9E9]];
VAR robtarget p280;
VAR robtarget p290;
p280:= [[355,0,6000-2810],[0.707106781,0,-0.707106781,0],[-1,0,-2,0],[2840,9E9,9E9,9E9,0,9E9]];
p290:= [[0,-355,6000-2810],[0.5,-0.5,-0.5,-0.5],[-1,0,-2,0],[2840,9E9,9E9,9E9,90,9E9]];
but it's terrible in case of more points. How solve this problem ?
You can do like this:
p280.extax.eax_a:=p280.extax.eax_a+400;
To loop through all your points, you can put them in an array like this:
VAR robtarget p{4};
VAR robtarget Target_10:=[[834.168657007,1657.814328764,1638.749733401],[0.822308775,-0.135789982,0.220336992,0.506775067],[0,0,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
VAR robtarget Target_20:=[[834.168537563,1041.87782245,1638.75011907],[0.822308749,-0.135789998,0.220337037,0.506775087],[0,0,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
VAR robtarget Target_30:=[[1507.165994697,1041.877901035,1638.749932632],[0.822308751,-0.135790027,0.220337,0.50677509],[0,0,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
VAR robtarget Target_40:=[[1507.165835032,1600.476877818,1638.750164826],[0.822308742,-0.135789991,0.220337023,0.506775105],[0,0,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
CONST robtarget Target_60:=[[2270.068689029,0,1638.75],[0.965925826,0,0.258819045,0],[-1,0,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
PROC Init()
p{1}:=Target_10;
p{2}:=Target_20;
p{3}:=Target_30;
p{4}:=Target_40;
PROC Path_10()
FOR i FROM 1 TO 4 DO
MoveJ p{i},v1000,z100,GWT_S1\WObj:=wobj0;
ENDFOR
PROC OffsetTargets(num nOffset)
p{i}.extax.eax_a:=p{i}.extax.eax_a+nOffset;
ENDFOR
PROC main()
Init;
Path_10;
OffsetTargets(500);
ENDPROCHenrik Berlin
ABB0
- 365 IRC5
- 84 OmniCore
