ListItem Help[MOVED]
Ercan
Hi everybody I have a little problem with LisItem. There is a sample below. And I want to change Item2 with a data. I mean I dont want to write manually. Thanks for help
The following example illustrates the data type listitem :
Example 1
CONST listitem list {3}:=[[stEmpty, "Item1"], [stEmpty, "Item2"],
[stEmpty, "Item3"]];
A menu list with Item1....Item3 to use in function UIListView.
Post edited by Jonathan Karlsson on
HiFirst you needed to define your list as persistant and not constant and then you can change the text using the text item in the recordEx.PERS listitem list {3}:=[[stEmpty, "Item1"], [stEmpty, "Item2"],[stEmpty, "Item3"]];! how to changelist{1}.text:="your text";Hope this was what you neededPer Svensson
Consat Engineering1 -
Thank you so much for your help. Its working0
- 364 IRC5
- 83 OmniCore
