Help for copy module[MOVED]
Ercan
Hi everybody
I need a help for easy problem. I want to copy a module totaly but I cant. I tried to save as module then load but I cant see.
Post edited by Jonathan Karlsson on
You have to go into the module and change the module name on the first row.
MODULE ModuleX
to
MODULE <Your module name>
But I must use just flexpendant for this work. I tried save as module changed module name then saved. But I cant see new module0
Since the question was posted in the RobotStudio forum I was assuming that you were using RobotStudio.
I have moved the question to the RobotWare forum instead.
Allright sorry0
if you save a module at the flexpendant with a new file name, the internal module name remain unchanged.
In case of you are loading the new module you will informed that a module with same are exist and can be overwritten.
To get a new module you should do the following steps:
- Save the module via the file menu
- Select file menu for the modules again and select change declaration
- Change the name of module to the new name
- Save the renamed module
- Reload the previous saved "old" module.
BR
Micky
- 367 IRC5
- 858 RAPID Programming
