How to reduce the size of FlexPendant in RobotStudio
I installed RS on my notebook computer. Whenever I click flexpendant, the popup window occupies most of the notebook screen. As a result of it, it is inconvenient to see flexpendant window and station layout window together at the same time. So I'm finding a way to reduce its size. How can I do that?
  • Janno
    Janno
    edited February 2014
    hi,
    the simple answer is there isn't an option (or i have never found it) to set the size of the flexpendant.
    however as the virtual flexpendant has an set amount of Width and Height pixels you can make it smaller bij turning up the resolution of your laptop screen.
