Instruction Templates double problem
I got a problem with instruction templates. For some reason I got two templates for MpSavePath -function. When trying to start AWPP I got output:
ArcWelding Item has already been added. Key in dictionary: 'mpsavepath' Key being added: 'mpsavepath'
and AWPP doesn't load correctly. I've tried to delete the other template and then save the station but that doesn't work out. Can I delete (in a right way) the other template some how?
I guess I solved the problem on my own. It seems that RS takes templates from RobotStudio\ProcessPac\ActionInstructionDescriptions\Arc -folder. For some reason I had two MpSavePath-templates there which apparently caused the problem. Deleded extra ones from folder and station and now it seems to be working fine.
-AT
