Force control in robotstudio machining package is not active
Hi all,
Force control in robotstudio machining package is not active in my robotstudio software. Any one have any idea?!
Abd El Khalick
  • The file!
  • Hello,
    you need to add the FC option to your virtual System:
    Then open a new Station with your existing System and select I-Start to activate the new Options
    Open Machining PP, it adds the FC instruction templates to your Station and you may use it as template....
    regards
    regards
    Christian
  • Now it works. Really I appreciate you help too much.
  • Hello,
    regards
    How can i "add the FC option to your virtual System" :smile:
    my device:
    How can i "add the FC option to your virtual System" smile
    my device:
  • AlexK
    AlexK ✭✭
    You might already have gotten an answer but in case you have not.
    You add the option through the Installation Manager in robotstudio. (Icon that looks like a IRC5 cabinet)
    Best regards
    Alexander Källberg
