COM port [MOVED]
jeremie
jeremie
edited April 2014 in Robot Controller
Hello every one !
the 620-1 option (Serial handling, and RS232 handling) is not installed on my IRC5 single cabinet,
Do I have to buy it ? or could I download the option key somewhere-else ?
I'm on RobotWare 5.07.01
best regards
Jérémie
Post edited by Jonathan Karlsson on
  • kioog
    kioog ✭✭
    In the past this was an option, if you upgrade your robotware to the latest one, serial handling is included so you dont have to change your key.
    BR
    Peter
  • Peter1 said:
    BR
    Peter
    Hello Peter !
    Yes the technical support tell me to upgrade RobotWare , I did it , but unfortunatly my flexpendant tell me now:
    "Axis Computer not found"
    Do you think its a common issue ?
    Thank you for your previous answer !
    Jérémie
  • Yes, solved by upgrading to RobotWare 5.12 , the option is free on this RobotWare Version.
    Note: RobotWare 5.15 gave me an error, dont know why, because my controller is hardware-compatible.
