Stop Movement manual mode
Hi , need stop moveme robots inmaal mode are somethg instruction or mode , I create task for monitoring and supervision and need stop robot and avoid customer movemnt manual.
thank
  • Micky
    Micky ✭✭✭
    you can use the instruction "StopMove" to stop the robot movement. To start the robot moving again, you have to use the instruction "StartMove".
    /BR
    Micky
