Error C0040401: no connection with controller
pjxia
Sorry, guys, I am new to ABB robotstudio.
I want to use ABB IRB140 for welding. Currently I try to study RAPID programming.
I have input all my models, including robot, tool and work piece, and then planned a short path, in the simulate module I synchronized the path to the VC already, then I can simulate the robot path, no problem.
And now, I want to test the RAPID programming. In the controller and RAPID module, I can see the generated RAPID code, and then if I want to change the RAPID code, and start execution of the RAPID code, there is C0040401 error: no connection with controller. However, even if I do not change any RAPID code, the same error.
How to fix this problem? Is there any examples to start RAPID programming?
Best regards
Hi, you have better chances getting an answer in the main RobotStudio forum. This is for Controller SDK CTP. I can see that we have lots of posts here which are not about Controller SDK.
Before I simply help everybody by moving them over, I would like to ask you if there is something in the user interface in the forum application that would make it easier to see the difference between the different forums
:-*0
