Robotstudio 5.60 Stationviewer --> Record to viewer problem
we are using Robotstudio for several years. After we finished the simulation we use the function Simulation / Record to viewer to generate the *.exe File ( afterwards i get the exe file in which the simulation can be runned by using the Play-Button). It worked well until now.
When i use Robotstudio 5.60 i can create the simulation like in 5.15. But when i start the exe File and run the simulation, the viewer stops after some seconds by an errormessage and i have to close it again. I tried to run the viewer on several computers, but always the same error.
The same simulation worked well in 5.15. I only replaced the robot 6640 by a 6700. So i can not go back to 5.15 anymore.
Is this a bug in 5.60, or ist there a solution?
Thank you for a feedback.
Regards
  • Hi, you have better chances getting an answer in the main RobotStudio forum. This is for Controller SDK CTP. I can see that we have lots of posts here which are not about Controller SDK.
    Before I simply help everybody by moving them over, I would like to ask you if there is something in the user interface in the forum application that would make it easier to see the difference between the different forums
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • There was a problem with 64-bit station viewers in RobotStudio 5.60 that appeared on some PCs. This problem is solved in 5.61 that is available for download.
    There is however a remaining problem that appears on PCs with built-in graphics.
    I recommend you to try with RobotStudio 5.61, and if it still fails, share a snapshot of the error message and we can take it from there.
    /Henrik
    ABB
