API documentation in RS >= 5.60 ?
apox
where do I find the API documentation ?
In previous versions it was located under $Programfiles\ABB Industrial IT\Robotics IT\RobotStudio 5.XX\Help\en\APIDocumentation.chm
Regards,
ASC
Regards,
ASC
You can find updated API documentation online at:
The RobotStudio SDK is no longer distributed with the RobotStudio download/installer. Instead it has it's own seperate installer available on the Developer Center.
http://developercenter.robotstudio.com/downloads
So if you download and install the RobotStudio SDK you will find it in the same location as usual.
John
Developer Center0 -
Great :-)Thank you for the hint, it is good to have an offline documentation.0
