Rapid beginner. How do I find certain bytes in a long string [MOVED]
A monorail conveyor system sends a 7 bytes long signal in an infinite loop via RS232 to the Com1 port of my IRC5. The start byte is 1 and the stop byte is 3. How to find the first byte
and save all the bytes in 7 different variables.
And how to set the parameters of the com1 port to the specitications i need (E.g. 9600 baud, 1.5 stop bits, no parity, no control characters.).
Post edited by Jonathan Karlsson on
Is the problem unclear or does really nobody know how to solve that problem??
- 361 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
