Creating a Robot system
Hello all
I have created a robot system with the system builder. I have added parameters to my system and have also added a . sys file to my home folder. then I finished the system builder process, created boot media. C-started my controller and installed the new system.
the problem is, that when the controller restarts the .sys file is not in my home folder and only some of the parameter are what I changed.
the on parameter is Controller>Automatic loading of modules> loading my .sys module that should be in my home folder.
if I take the same parameter I added into my system build and load them through RSO to my controller, then I have my parameter for automatic loading of modules.
does any one know what's going on???
never mind I figured how to get it to work.
I had to modify my system and first remove the parameters I want to include in the build. then click finish. then modify the system again and now include the parameters once again and click finish.
create boot media, install system onto controller. and presto! it now works.
So we have tried that, but we can not get our robot to get past booting sometimes. It keeps talking about mismatches? Do you have any help, how to create a system isn't really clearly laid out that we can find.0
