Array in FPSDK
Hi again..
one more question...From my memory, I used to use arrays in VB6, such as BoxArray, CheckListBoxArray and so on...these array controls are not appeared on FPSDK. Can't I use these? or another way??
spaik
Control arrays are not supported in VB.Net.
Search the topic "control arrays" for suggestions about other ways to identify controls in your controls collection.
Russell Drown0 -
in the new .Net Runtime Environment it seems that Control arrays are working, the following definition is working with .Net 2005 and FP SDK 5.07:
private ABB.Robotics.Tps.Windows.Forms.Button[] btnGripper1 = new ABB.Robotics.Tps.Windows.Forms.Button[3];
:for (int i = 0; i < 3; i++)
btnGripper1 = new ABB.Robotics.Tps.Windows.Forms.Button();
this.btnGripper1.Size = new System.Drawing.Size(80, 50);
this.btnGripper1.Location = new System.Drawing.Point(150 + (90 * i), 80);
this.btnGripper1.Text = "P" + Convert.ToString(i + 1);
this.btnGripper1.Tag = i;
this.btnGripper1.Visible = true;
this.btnGripper1.Click += new EventHandler(btnGripper1_Click);
}The tag item is used in theevent handler to estimate which button was pressed...
- 858 RAPID Programming
