Socket communications on IRC 4 ?
abood
I have a RAPID program that listen to the received sockets in the controller and unpack them for reading some instructions.
the program is running fine on IRC 5. but when I try to run it on IRC 4 the controller shows syntax errors and it doesn't recognize the socket data types (socketdev, socketstatus).
I couldn't find anything related to socket communication the RAPID manual for IRC 4. Does this mean that the IRC 4 doesn't support the socket communication ?
if so, is there any other alternative way of communication to fix the issue?
Regards,
Regards,
yes, you are right the S4-Controller does not support socket messaging.
Only serial communication is possible.
/BR
Micky
