Routine with parameters
NRMartin
Hi everyone!
I'm making an application with C# using PC SDK to work with virtual controllers.
One of the implemented features allows to load a routine and execute it from the application.
However, I wonder if it would be possible to execute a routine which needs parameters.
Can anyone help me?
Thanks in advance!
Can anyone help me?
Thanks in advance!
We also need to know about this .. thanks in advance.0
No one?
This is not possible, since what you are doing with the SDK (similar to the Flex Pendant), you are moving the Program Pointer to a routine. The runtime can't figure it out the parameters at this point.
Have you though about work around?
- If the name of the routine always the same?
- What type of parameters is expecting?
Based on these two questions, you can have a routine without parameters that calls your target routine.
BE
Carlos Martinez
ABB0
