screenmaker Check
in ScreenMaker
Hej Hej.
I ve got the actual Dualarm Robot(assembler) with a IRC5. I would like to check if I can use ScreenMaker to create my own app. In robotstudio I create an App and transmit it to the robot but nothing happend. I cant find my view.
The ScreenMaker Doctor founded one problem:"missing entry in system configuration file" -> Add ScreenMaker.sys as a modul that can be automatically loaded.
I did this and added "Release:/options/gtpusdk/ScreenMaker.sys" to "automatic loaded Modules. But its still not working (the Doctor is also still saying the same).
So what could i do next? Is there anything where I can check that it's possible to use ScreenMaker at all?
best regards Tobi
(Ah and Robotware 5.13 is installed)
Hi Tobias,If you have the software option "617-1 FlexPendant Interface" in your robot you should be able to use ScreenMaker apps.The app should be visible on the "ABB page".Regards,AndersBest regards,
ABB Robotics0
