Really slow Simulation problem
I have a problem with my simulation.
It works OK, but sumetimes it's really really slow. The parameters in the path are OK, and the simulation should work at a normal speed. The only thing different is a few new targets, but nothing different about speed.
Is there some parameter about the simulation speed? is a problem of the programming of the path??
  • Hi,
    Did You get any answer? I have a similar problem. RS5.15.02. Had a simulation with two robots working fine. Now I changed some robtagets and one of the robots has started to go really slow i simulation.
    Thanks in advance,
    Janette
