Few problems
we have few problems with RobotStudio.
1. when we prepare some changes on RS online and we stop the running program, pointer goes to 1. line of programm. So we must search again where we want to place changed instruction (if you need to make some change fast during production, you can´t because you must always search for correct line after you stop machine).
2. when we prepare station with "signal connections" in "Simulation" > "Station logic", everytime we reboot the virtual controller, we must make connection again (when you have station with 30 signals, it takes really long time to click 30 times edit and ok everytime you need to reboot".
3. We can´t watch signal analyzer online in offline view or transfer it to other computer. (this great feature is usable only when you are standing next to real controller).
Thank you for support.
Hello Jiri,What version of RobotStudio are you using? The problems you describe in point one and two should have been solved in the latest release (5.61).If you would like to use the Signal Analyzer when you not are connected to the real robot you need to setup a virtual copy of your real robot. The easiest way to do that is to use "Go Offline" (when you still are connected to the real robot) that will create a Virtual Controller from your real robot and load it in a RobotStudio station.You can also export the result from Signal Analyzer to an excel file.Regards,AndersBest regards,
we are using 5.61 version and problems 1 and 2 are still there.
We know that it´s possible to export data to xls, but it´s really complicated to make data readable or make some graph from this data.
