Help! Get the current TCP pose
davidina
Hello everyone,
I was following tutorial in the PC SDK Manual and I want to read the current TCP pose in C# with the following:
public void Read_Current_Pose()
NetworkScanner scanner = new NetworkScanner(); scanner.Scan();
Controller acontroller = new Controller(scanner.Controllers[0].SystemId);
acontroller.Logon(UserInfo.DefaultUser);
MotionSystem aMotionSystem = acontroller.MotionSystem;
MechanicalUnitCollection aMechCol = acontroller.MotionSystem.MechanicalUnits;
MechanicalUnit aMechUnit = acontroller.MotionSystem.ActiveMechanicalUnit;
try
if (acontroller.OperatingMode == ControllerOperatingMode.Auto)
using (Mastership m = Mastership.Request(acontroller.Rapid))
RobTarget CurrPos = acontroller.MotionSystem.ActiveMechanicalUnit.GetPosition(CoordinateSystemType.WorkObject);
RapidData rd = acontroller.Rapid.GetRapidData("T_ROB1", "Module1", "rbt")
CurrPos = (RobTarget)rd.Value;
Console.WriteLine(CurrPos);
I wrote rbt:= CRobT(\Tool:=MyTool \WObj:=wobj0); from RAPID but I am not sure if that is the way to write it to get pose. I want to get the current TCP matrix, but when I printed the output it was not was I expected, as I got this output : [[1587.428550103,-522.655533591,0],[0,0,1,0],[-1,1,-2,0],[9E9,9E9,9E9,9E9,9E9,9E9]];. Please what am I doing wrong?
Any help will be appreciated. Thank you.
David
try
David
the pose consists of 2 parts a pos [x,y,z] and a rotation [q1,q2,q3,q4]the layout you'r gettin is the complete robtarget which consists of a [pos][rotation][config][external axis]The values u are getting are related to wobj0 which is usualy equal to the robot base frameRobWelding
The Netherlands0 -
Thank you very much Sjoli. I understand better now. Since I am getting myself familiar with PC SDK with Robostudio my knowledge is still limited. Since the matrix will consist of both rotation and translation, please is there a way to read that into C#? What I actually want to do is to obtain matrix by:
Move robot to a position --> Read the the current position and rotation that will result in matrix --> Move robot to next position --> Read again --> until all positions reached and read.
I need a way to approach this sequence. Can you please show some light on how to proceed?? Thanks a lot!!
First get the CRobTThen you can save the pos and orient(q1-q4) data from the target to there own datatypeMODULE Module1pers robtarget p1:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];VAR pos pos1:=[0,0,0];VAR orient orient1:=[1,0,0,0]PROC Example()p1:=Crobt(\Tool:=tool0\WObj:=wobj0);pos1:=p1.trans;orient1:=p1.rot;ENDPROCENDMODULERobWelding
The Netherlands0 -
Following your code and with your help, I am now able to save the pos and orient. Thank you very much. I can write the code to convert them to form the matrix from the C#.... Or is there any better way to covert the output to rotation matrix instead of me writing that code? ( I need it with the transformation matrix from the camera to make the calibration)
Once again, thank you very much.
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
